3 Replies Latest reply on Aug 20, 2013 10:55 PM by Artem Taturevych
    Selecting outer edge of face
    Chris Johnson
      Hi All,
      so basically Im trying to create a macro that  changes the selection from the pre-selected (circular) face to its outer edge.
      I kinda think it may be done with .getedges but i dont know how to implement it.
      does anyone have an example of how this could be done?
      thank you
      Chris
        • Re: Selecting outer edge of face
          Artem Taturevych
          Hi Chris,
          Here is the macro:
          Dim swFace As SldWorks.Face2
              Set swModel = swApp.ActiveDoc
              Set swFace = swSelMgr.GetSelectedObject6(1, -1)
              If Not swFace Is Nothing Then
                  Dim vLoops As Variant
                  vLoops = swFace.GetLoops
                  Dim i As Integer
                  swModel.ClearSelection2 True
                  For i = 0 To UBound(vLoops)
                      Dim swLoop As SldWorks.Loop2
                      Set swLoop = vLoops(i)
                      If swLoop.IsOuter() Then
                          Dim vEdges As Variant
                          vEdges = swLoop.GetEdges
                          Dim j As Integer
                          For j = 0 To UBound(vEdges)
                              Dim swEdge As SldWorks.Entity
                              Set swEdge = vEdges(j)
                              swEdge.Select4 True, Nothing
                          Next
                  Next
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
