0 Replies Latest reply on Aug 19, 2013 6:31 PM by Anshul Pandeys
    View components issues
    Anshul Pandeys
      All,
      I am a tyring again as my original question went unanswered.
      I am looking for some pointers on following 2 line items.
      1. ) There are times when I had a working view – (view is shown in drawing, can select it and other operations can be done.) but on querying view.getvisibleComponents will return null.
      1. ) Can you help me understand under how does a view goes from valid to invalid state. ? There are times when the  I do checks like following but the line highlighted in yellow still throws an exception.
                     Object[] vDrawChildCompArr2 = GetComponentsInView(ref model, viewName); // get the drawing docs in the document.see call below.
                        foreach (var c1 in vDrawChildCompArr2)
                          Component2 comp2 =null;
                          DrawingComponent comp = c1 as DrawingComponent;
                          if (comp is DrawingComponent)
                              comp2 = comp.Component;
                              if (comp2 != null)
                                  String compName = comp2.Name2;
                                  sb2.AppendLine(compName );
                          else if (c1 is Component2)
                              String compName  = (c1 as Component2).Name2;
      public static object[] GetComponentsInView(ref ModelDoc2 swModel, string viewName)
                                    try
                                              SolidWorks.Interop.sldworks.View swView = GetActivatedView(ref swModel, viewName);
                                              DrawingComponent swRootDrawComp = (DrawingComponent)swView.RootDrawingComponent;
                                              object[] vDrawChildCompArr = (object[])swRootDrawComp.GetChildren();
                                              swModel.ClearSelection2(true);
                                              return vDrawChildCompArr;
                                    catch (System.Exception ex)
                                              throw ex;
