HI,
im doing a lot of tube routing on pnematic systems, and we have a set of tubes setup on the system, but im not sure who to configure them and could do with some help.
As we manufacture the pipework inhouse we have specifid bend radi that we use and minimum tube stubs.
How do i change this on the tubing so its automatic, like a bend table.
for example
and also fixing the bend radius
so the bend radius is correct for the diameter tube
thanks
(by the way i have looked on here but cant find what im looking for or im not searching in the right place!)
Hi Mark,
It appears that you are using a default tube that is in the system already. These tubes have predefined settings.
What I have done is added to the 'Tubes folder' with custom tubes of different sizes in a Design Table with the different custom settings.
Hope this helps,
Dave
