1 Reply Latest reply on Aug 16, 2013 4:31 PM by Chris Johnson
    Multi-Select using GetObjectByPersistReference3
    Chris Johnson
      Hi All,
      So Im wanting to multi select two circles and add a dimension between them (basicly a wall thickness dimension) but Im not sure how to add both selections to the selection manager. Originally I was  going to simply select the first circle and then the second, thinking this would add them both to the selection manager.
      Im kinda thinking this may require an array but I have zero experience with arrays....how would you suggest multi-selecting sketches from persistent ID?
      'Add Wall thickness Dimension
          'Re-select OD sketch Segment
              Set swSketchSeg = swModel.Extension.GetObjectByPersistReference3(ODSketch, Empty)
              swSketchSeg.Select2 False, Empty
          'Re-Select ID Sketch Segment
              Set swSketchSeg = swModel.Extension.GetObjectByPersistReference3(IDSketch, Empty)
      thanks
      Chris
        • Re: Multi-Select using GetObjectByPersistReference3
          Chris Johnson
          NM,
          I figured it out....
                  Set swSelData = swSelMgr.CreateSelectData
                  Set swSketch = swModel.GetActiveSketch2
                  vSketchSeg = swSketch.GetSketchSegments
                  For i = 0 To UBound(vSketchSeg)
                  Set swSketchSeg = vSketchSeg(i)
                  vSketchSegID = swSketchSeg.GetID
                  bRet = swSketchSeg.Select4(True, swSelData)
                  Next
