I'm basically a newb at this and this is my first time using solidworks. This may be a very simple thing to do.
So basically i build out an object which is composed different features such as Extruded Boss/Base, Extruded Cuts etc. i dont see the part as a single solid body, but made up the seperate extrude boss/base and extruded cuts...
Is there a way to turn the features into a single solid body or is that not needed if i'm going to CAM with this?
Taha
Your part is a solid body as you don't have a SolidBodies Folder at the top of your tree. I believe it's usually under Annotations.
All the features in your tree are just the different steps used to make up your part which can be modified or rolled back to at a later date.
