1 Reply Latest reply on Aug 15, 2013 8:03 AM by Artem Taturevych
    Getting units in SW Assemblies
    Mohammad Shaheer Zubairi
      I have a SW assembly which has some angular dimensions. When I click on those dimensions in GUI, the dimension property window appears on the left side and I can read the Primary Value tab which has two boxes. The top one gives the parameter name (D1@Sketch1), while the bottom one shows the magnitude and units (60.00deg).
      I can read the D1@Sketch via API, however for mangitude it just gives me 1.04719577, which is 60 degrees in radians.
      I need to know how can i read the 'deg' in 60.00deg by using an API. I am doing some parameterization and need to differentiation angles from other parameters types. I know that one way to do so would involve using Dimension Text, however that requires a pre-requsite that every dimension should have the appropiate dimension text.
      Any help would be much appreciated.
      Regards,
      Mo
