hi
trying to learn solidworks but gut stuck in few things
in the file attached two sketches
1 , there are 2 points almost touching each other at the end of the blue and red sketches , how can i make them perfectly touching ?
2. how can i make the blue sketch follow the contour of the top side red sketch ?
you i have a top and side view of an object but i cant really make an object out of it
thanks for your time and help
I can't open your part due to future version.
Blue = underdefined
Red = overdefined
This means the sketch has to much relations.
If you want to let the points perfectly touch, hold control and select the points. Then on your right you must click "Coincident"
Please post a screenshot to let me see the contour of the part you are referring to.
~Thomas
