Hi All,
We can find buckling load factor in nonlinear analysis through arc control method but while using force control method, the study will stop when the buckling is predicted more.
But while iam doing this, By using arc control method the buckling load factor falls below 1 and so buckling is expected. At this time if we use force control method the solution will stop but when iam doing, it didn't happen. I dont know the reason can anyone help me regarding this. thank you
are you asking if it is possible to switch between arc and force control?
