4 Replies Latest reply on Sep 18, 2013 1:27 PM by John R. Sitek
    Move block in drawing using macro.
    John R. Sitek
      I think I need to use SelectByID2 and MoveOrCopy but not sure.  The block is located on the sheet background, not foreground.  Please just paste the code if you respond.  Please do not point me elsewhere.
        • Re: Move block in drawing using macro.
          Keith Rice
          John,
          A macro that accomplished this would require you to select the block (unless you wanted this action to occur to all blocks on the foreground, programmatically---but you didn't specify this). Once selected, you would want to have a keyboard shortcut linked to a macro that simply did this:
          1. Cut the block using ISldworks::RunCommand
          2. Leave Edit Sheet Format using IDrawingDoc::EditSheet
          3. Rebuild the par tusing IModelDoc2::ForceRebuild3
          4. Plaste the blockusing ISldworks::RunCommand
          When it's all said and done, you've saved only a few mouse clicks and a keyboard stroke. So I assume you're looking for something more complex than this, but I hope this gets you headed in the right direction.
          Keith
          Learn the SolidWorks API
              John R. Sitek
              As stated, the block is on the sheet background, and already exists.  I know the block name and the current coordinates would have to be extacted depending on the sheet scale.  I need to do this in VBA.
                  Simon Turner
                  Option Explicit
                  Option Compare Text
                  Dim Part As ModelDoc2
                  Dim myUtil As MathUtility
                      Dim selMgr As SelectionMgr
                      Dim sa As Variant
                      Dim myBlockDef As SketchBlockDefinition
                      Dim myMgr As SketchManager
                      Dim i As Integer
                      Dim myFeat As Feature
                      Set Part = swApp.ActiveDoc
                      If Part Is Nothing Then
                          MsgBox "No active Drawing document"
                          Exit Sub
                      If Part.GetType <> 3 Then
                          Exit Sub
                      Set myMgr = Part.SketchManager
                      Set myUtil = swApp.GetMathUtility
                      sa = myMgr.GetSketchBlockDefinitions
                      If IsEmpty(sa) Then Exit Sub
                      For i = 0 To UBound(sa)
                          Set myBlockDef = sa(i)
                          Set myFeat = myBlockDef.GetFeature
                          If myFeat.Name = "Block1" Then
                              MoveBlockInstances myBlockDef, 0.15, 0.25
                      Next
                  Sub MoveBlockInstances(myBlockDef As SketchBlockDefinition, x As Double, y As Double)
                      Dim myInst As SketchBlockInstance
                      Dim sa As Variant
                      Dim i As Integer
                      sa = myBlockDef.GetInstances
                          Set myInst = sa(i)
                          MoveBlockInstance myInst, x, y
                      Next
                  Sub MoveBlockInstance(myInst As SketchBlockInstance, x As Double, y As Double)
                      Dim sa As Variant
                      Dim i As Integer
                      Dim mpt As MathPoint
                      Dim p(2) As Double
                      Set mpt = myInst.InstancePosition
                      sa = mpt.ArrayData
                      p(0) = sa(0) + x
                      p(1) = sa(1) + y
                      p(2) = 0
                      sa = p
                      Set mpt = myUtil.CreatePoint(sa)
                      myInst.InstancePosition = mpt
