4 Replies Latest reply on Aug 11, 2013 9:28 PM by Jin Fui Chong
    How to save the animation in solidworks motion study using API?
    Jin Fui Chong
      Dim swModelDocExt As SldWorks.ModelDocExtension
      Dim swMotionMgr As SwMotionStudy.MotionStudyManager
      Dim swMotionStudy1 As SwMotionStudy.MotionStudy
      Dim swMotionStudy2 As SwMotionStudy.MotionStudy
      Dim swMotionStudy3 As SwMotionStudy.MotionStudy
      Dim swSaveAVIData As SwMotionStudy.AVIParameter
      Dim boolstatus As Boolean
          Set swModel = swApp.ActiveDoc
          Set swModelDocExt = swModel.Extension
          Set swSaveAVIData = swMotionMgr.CreateAVIParameter()
          swSaveAVIData.FramePerSecond = 7.5
          swSaveAVIData.SaveEntireAnimation = True
          swSaveAVIData.OutputType = 1 ' Save as an .avi file
        • Re: How to save the animation in solidworks motion study using API?
          Artem Taturevych
          After you have created the AVIParameter object just call the MotionStudy::SaveToAVI and pass output file name and the AVIParameter object.
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
              Jin Fui Chong
              Hi Artem,
              what do you mean by AVIParameter object? Do you have any example? i have no idea about call the MotionStudy::SaveToAVI..
                  Artem Taturevych
                  Hi Jin,
                  Check this:
                      Set swMotionMgr = swModelDocExt.GetMotionStudyManager()
                      Set swMotionStudy1 = swMotionMgr.GetMotionStudy("Motion Study 1")
                      swMotionStudy1.SaveToAVI "C:\MyAnim.avi", swSaveAVIData
                      Jin Fui Chong
                      Hi Artem,
                      Thanks for your reply. But my code is not working. Do you have any idea about this?
