Hello, I got a relatively simple question, but I can't find a solution by now in the program. Actually I want to use jointed fixtures with specific free rotations on a simulation of a plate. By now the only line support I find in SW is completely fixed. In UGS Nastran I could freely set up the fixtures by selecting (lines/areas/points) and then choosing between translation x, y, z and rotation x, y, z wich was quite good.
With beams I had the posibility of using the deposited mass tool but I dont know if thats a good choice for a line support, even its quite complicated to set up because you always need the specific center point.
Thank you
Greetings Wolfgang
Not sure what you mean by "jointed fixture".
but based on what you're describing, you might want to check this out: https://forum.solidworks.com/thread/70477?tstart=30
