1 Reply Latest reply on Aug 9, 2013 6:31 AM by Deepak Gupta
    How to get the directory or path of selected file and redirect it to sFileName?
    Jinhong Chong
      Dim Filter As String
      Dim fileName As String
      Dim fileConfig As String
      Dim fileDispName As String
      Dim fileOptions As Long
      Dim a As Variant
      ReDim a(0 To 100)
      Filter = "Distance value (*.txt; )|*.txt;*.txt;*.txt|Filter name (*.fil)|*.fil|All Files (*.*)|*.*|"
      fileName = swApp.GetOpenFileName("File to Attach", "", Filter, fileOptions, fileConfig, fileDispName)
      Debug.Print fileName
          Dim arr() As String
          Dim sFileName As String
          Dim iFileNum As Integer
          Dim sBuf As String
         sFileName = "C:\Users\hong\Desktop\msg.txt"
          If Len(Dir$(sFileName)) = 0 Then
              Exit Sub
          iFileNum = FreeFile()
          Open sFileName For Input As iFileNum
          Dim i As Integer
          i = -1
          Do While Not EOF(iFileNum)
              i = i + 1
              ReDim Preserve arr(i)
              Line Input #iFileNum, sBuf
              arr(i) = sBuf
              Debug.Print sBuf
          Loop
          Close iFileNum
          MsgBox arr(1)
