1 Reply Latest reply on Aug 8, 2013 7:11 PM by Artem Taturevych
    How to assign each line of the text file into array?
    Jinhong Chong
      Sub ReadAsciiFile()
          Dim sFileName As String
          Dim iFileNum As Integer
          Dim sBuf As String
          sFileName = "C:\Users\hong\Desktop\msg.txt"
          If Len(Dir$(sFileName)) = 0 Then
              Exit Sub
          iFileNum = FreeFile()
          Open sFileName For Input As iFileNum
          Do While Not EOF(iFileNum)
              Line Input #iFileNum, sBuf
              Debug.Print sBuf
          Loop
          Close iFileNum
          MsgBox (sBuf)
        • Re: How to assign each line of the text file into array?
          Artem Taturevych
          Check this:
          Sub ReadAsciiFile()
              Dim arr() As String
              Dim sBuf As String
                  Exit Sub
              Dim i As Integer
              i = -1
                  i = i + 1
                  ReDim Preserve arr(i)
                  arr(i) = sBuf
                  Debug.Print sBuf
              Loop
              Close iFileNum
              MsgBox sBuf
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
