7 Replies Latest reply on Aug 9, 2013 6:42 PM by Oleg Bezyaev
    PropertyManagerPage autohiding.
    Oleg Bezyaev
      I create PropertyManagerPage from WinForm control. When I highlight/focused my selectionbox and select any sketch line my PMP is closing. If I select faces, edges - PMP steel open. Why? And how can I fix this so that my PMP still remained open.
        • Re: PropertyManagerPage autohiding.
          Artem Taturevych
          Do you say that your created the PMP with ActiveX control? Try to use the SldWorks::CreatePropertyManagerPage with swPropertyManagerOptions_LockedPage option.
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
              Oleg Bezyaev
              Hi Artem.
              PMP was created with "IPropertyManagerPageWindowFromHandle".
              The proposed code no results.
              controlType = (int)swPropertyManagerPageControlType_e.swControlType_WindowFromHandle;
              align = (int)swPropertyManagerPageControlLeftAlign_e.swControlAlign_LeftEdge;
              options = (int)swAddControlOptions_e.swControlOptions_Enabled +
                                    (int)swAddControlOptions_e.swControlOptions_Visible +
                                    (int)swPropertyManagerPageOptions_e.swPropertyManagerOptions_LockedPage;
              usercontrol1 = (IPropertyManagerPageWindowFromHandle)group1.AddControl(UserControl1ID, controlType, "Dot Net Control", align, options, "This is a WinForm");
              usercontrol1.Height = 970;
              If I select object with type swSelEXTSKETCHSEGS - PMP is closing.
                  Artem Taturevych
                  Hi Oleg,
                  Strange. Have never used WindowFromHandle. Always using the ActiveX: swControlType_ActiveX
                  Can you try this?
                  Regards,
                      Oleg Bezyaev
                      If I create the control as swControlType_ActiveX, I will have my UserControl (WinForms) make a separate project? As with the example TaskPane.
                      Now I have my UserControl (PMP_Part) added as part of the current project.
                      If I just replace controlType on swControlType_ActiveX, the panel will not be created.
                      controlType = (int) swPropertyManagerPageControlType_e.swControlType_ActiveX;
                      align = (int) swPropertyManagerPageControlLeftAlign_e.swControlAlign_LeftEdge;
                      options = (int) swAddControlOptions_e.swControlOptions_Enabled +
                                             (int) swAddControlOptions_e.swControlOptions_Visible +
                                             (int) swPropertyManagerPageOptions_e.swPropertyManagerOptions_LockedPage;
                      usercontrol1 = (IPropertyManagerPageActiveX) group1.AddControl (UserControl1ID, controlType, "Dot Net Control", align, options, "This is a WinForm");// NOT NULL
                      bool bRet = usercontrol1.SetClass ("3e883709-cf1a-4231-b57a-8c795ab68e9e", "");//RETURN TRUE
                      public void Show()
                                  myControl = new PMP_Part(userAddin);
                                  if (swPropertyPage != null)
                                      swPropertyPage.Show();
                                  myControl = usercontrol1.GetControl();//RETURN NULL
                      public int OnActiveXControlCreated(int id, bool status)// STATUS IS FALSE
                                  //return -1;
                                  return 0;
                    Oleg Bezyaev
                    I had to put the property into a function "protected void CreatePropertyManagerPage ()"
