2 Replies Latest reply on Aug 8, 2013 1:36 PM by Matt Martens
    Expand/Restore Task Pane
    Matt Martens
      Is there a way to program a macro to expand/restore the task pane size (see attached picture)? I would like to write a macro that toggles this and assign to a shortcut key.
      Any help would be appreciated.
      -Matt Martens
        • Re: Expand/Restore Task Pane
          Josh Brady
          I don't see a way to hide it in the API based on a quick look, although I didn't do an exhaustive search.
          You can display it with the following macro, which pins and then unpins it.
              With Application.SldWorks
                  .TaskPaneIsPinned = True
                  .TaskPaneIsPinned = False
              End With
              Matt Martens
              This will work if there are no other solutions.
              The reason i want the expand/restore button is i would like it to stay pinned at all times so i can still view it in a narrow state and then toggle the size of the pane with the press of the shortcut key when i need to access items in the task pane.
              Thanks.
