I keep getting the attached error after solving the model. Model is very simple, just a pipe with two end caps, volumetric flow through the inlet and ambient pressure at the outlet. Any advice?
after running the model. is it stopping you from doing anything with the software as well?
do you know how the software was installed? sounds like permissions or install issue. specifically i'd make sure the prerecs are installed, seee what happens if you disable UAC, run solidworks as an admin and then worst case uninstall/reinstall with anti virus and antispyware tools disabled.
If you can run the add-in when you're logged into Windows as a different user, then your Windows account has become corrupted and you need to have it re-issued.
