Getting the following error:
"Failed to save the workflow to the database.
Cause: Couls not access the item in the database."
If I delete a transition then the workflow will not save.
If I move a state and then save (without deleting anything) then the workflow saves normally.
Why is this happening and how do I fix it?
Gary.
Gary,
Check your transition conditions, more than likely you've changed a variable name that was used by them. Also check you local log file anytime you get the message "Could not access item in database". The descriptive message will be there.
