Hi. I'm running a simulation of a cylindrical part and I'd like to be able to extract the max (and min and average...) along the center axis. That is, at each axial location I'd like to have the value of the stress and/or strain. Ulitmately, I'd like a plot of the value vs the axial position.
Is this easily possible? If so, how?
Kelly
you can't choose an axis it has to be a model edge. so to do that you need to split your model into multiple bodies so there is an edge to select. try with a cube and select the edge, you'll see what i mean. the spacing will not be perfect, it will be wherever the closest node is.
