I'm currently having a (seemingly random) issue when trying to modify sketch dimensions of parts...
usually when I'm entering dimensions (regardless of base template units) I'm able to enter values in the following fashion:
ex)
1"
1.5"
1 1/2"
solidworks will normally accept these inputs and convert whatever entry to the base units of the template...
now, some times when I enter values followed by the " (inch) mark I'm given the following pop-up...
ex)
"Create a new global variable named "1”" ?"
Yes / No
^ where I would have tried to enter 1" as my dimensional value
I do not have any equations in the parts / assemblies... or any active filters that would think I'm editting equations... the odd thing is that it doesn't prompt this "error" for every dimensional change, I have not yet observed a pattern as the problem has just surfaced
I am still able to enter inch values by typing "in"
anyone have any advice? seen this problem before?... not a HUGE deal but even 1 extra letter when entering dimensions becomes a chore after the 10th / 100th / 1000th change...
thanks again,
- Jeff
Jeff,
The other designer in the dept. is having the same problem. We have just upgraded to SW2014 SP1.0. Are you using 2014 as well? May be a bug with the upgrade?
Deanna
