4 Replies Latest reply on Jun 13, 2014 6:36 AM by Darren Smith
    Notification when user closes a file?
    David Watkins
      I have been looking for a way in VBA to get a notification of the file that a user just closed or is trying to close (similar to how when you try to close an unsaved file and are asked if you would like to save the file). I was thinking that FileCloseNotify would work but sadly it seems that only works if you call closeandreopen which I am not. I have been working on this all day and not much to show for it so a point in the right direction would be great!
      David
        • Re: Notification when user closes a file?
          Josh Brady
          I'm guessing you may want to look at the DestroyNotify for each individual document.  Not sure though.
            Artem Taturevych
            DPartDocEvents_DestroyNotify2EventHandler
            DAssemblyDocEvents_DestroyNotify2EventHandler
            DDrawingDocEvents_DestroyNotify2EventHandler
            But you need to setup the documents map. As Josh said this is the event for individual files. So you need to handle the DSldWorksEvents_DocumentLoadNotify2EventHandler to add the document to the map. Take a look at EventsHandling.vb file generated by add-in which shows how this should be setup. You may need to port this to VBA.
            ____________________________________________________
            Regards,
            Artem Taturevych, Application Engineer at Intercad (Australia)
            translationXpert – add-in to translate SolidWorks models
            myIntercad an integrated tool for SolidWorks Professionals
            LinkedIn SolidWorks API Education Group
                David Watkins
                Thanks Artem for the tip about the estroyNotify2 events. I think I finally understand how events work. I do not understand or know how to setup a document map or to use handle ( the best I can tell, handles are available in VB.NET but not VBA.) but I did come up with something that works. The code below is triggered any time the active doc is changed and a msgbox is sent when the doc is being closed just as a test.
                My main Module:
                Public FileCloseListener As New FileCloseClass
                FileCloseListener.MonitorSolidWorks
                My FileCloseClass :
                Dim WithEvents swApp As SldWorks.SldWorks
                Dim WithEvents swAssem As SldWorks.AssemblyDoc
                Dim WithEvents swPart As SldWorks.PartDoc
                Dim WithEvents swDrawing As SldWorks.DrawingDoc
                Public Sub MonitorSolidWorks()
                Set swModel = swApp.ActiveDoc
                Private Function swApp_ActiveDocChangeNotify() As Long
                Dim OpenFile As String
                Dim OpenFileSplit() As String
                OpenFile = swModel.GetPathName
                OpenFileSplit = Split(OpenFile, ".")
                Select Case OpenFileSplit(1)
                    Case "sldprt", "SLDPRT"
                        Set swPart = swModel
                    Case "sldasm", "SLDASM"
                        Set swAssem = swModel
                    Case "slddrw", "SLDDRW"
                        Set swDrawing = swModel
                End Select
                End Function
                Private Function swPart_DestroyNotify2(ByVal DestroyType As Long) As Long
                    MsgBox "This is closing " & swModel.GetPathName & "!"
                End Function
                Private Function swAssem_DestroyNotify2(ByVal DestroyType As Long) As Long
                End Function
                Private Function swDrawing_DestroyNotify2(ByVal DestroyType As Long) As Long
                End Function
