2 Replies Latest reply on Aug 5, 2013 12:22 PM by Hersh Sridhar Iyer
    Issue with Merge Points on DXF Import
    Hersh Sridhar Iyer
      I am looking to import a DXF file and extruding the sketch post import to a cetain thickness.
      The DXF import is done using the macro - http://help.solidworks.com/2013/English/api/sldworksapi/Import_DXF_File_into_Part_Sketch_Example_VB.htm.
      However, once imported, extrude on the sketch fails because of open contours which are a result of non-overlapping end points between the sketch edges.
      I was aware of this and hence depended on the "Merge Points Closer Than" check box which is provided in the DXF Import UI.
      If I import the DXF through the UI with the option to merge points (closer than 0.001) and then extrude the part, it comes out fine. The same thing done using the macro does not work. Please advise.
      Is there a way to apply the merge points setting while importing through the macro? The SetMergePoints() call does not result in the required merge.
      The DXF is attached for reference.
      Please advise.
      Hersh
        • Re: Issue with Merge Points on DXF Import
          Simon Turner
          First of all, you need to specify which sheet to load from the DXF. Last time I looked, you couldn't do that in the API, so I import the entire dxf as a 2D drawing, delete the unwanted sheets and then save back to DXF.
          Next, I use this code to import the new DXF to a sketch:
                      Set myImportData = swApp.GetImportFileData(myFileName)
                      myImportData.ImportMethod("") = swImportDxfDwg_ImportMethod_e.swImportDxfDwg_ImportToExistingPart
                      myImportData.SetMergePoints "", True, 0.2
                      myImportData.ImportDimensions("") = False
                      myImportData.ImportHatch("") = False
                      myImportData.LengthUnit("") = swLengthUnit_e.swMM
                      myImportData.ImportMethod(mySheetName) = swImportDxfDwg_ImportMethod_e.swImportDxfDwg_ImportToExistingPart
                      myImportData.SetMergePoints mySheetName, True, 0.2
                      myImportData.ImportDimensions(mySheetName) = False
                      myImportData.ImportHatch(mySheetName) = False
                      myImportData.LengthUnit(mySheetName) = swLengthUnit_e.swMM
                      Set myFeature = Part.FeatureManager.InsertDwgOrDxfFile2(myFileName, myImportData)
              Hersh Sridhar Iyer
              Hi Simon,
              Thanks for the suggestion. I am not sure if the macro you suggested solves my problem which is extruding the imported DXF sketch to a specified thickness. Basically, the mergePoint call is not being honored if I use swImportDxfDwg_ImportMethod_e.swImportDxfDwg_ImportToExistingPart.
              I contacted the API support folks at SW and they  helped me out by suggesting the following macro for DXF import which uses
              importData.ImportMethod("") = SwConst.swImportDxfDwg_ImportMethod_e.swImportDxfDwg_ImportToPartSketch
              This does the job for me now.
              Dim swApp As Object
              Dim Part As Object
              Dim boolstatus As Boolean
              Option Explicit
                  Dim filename As String
                  Dim longerrors As Long
                  Dim retVal As Boolean
                  filename = "C:\Users\hiyer\Desktop\Current\dxf\test.DXF"
                  Dim importData As SldWorks.ImportDxfDwgData
                  Set importData = swApp.GetImportFileData(filename)
              ' Import method
                  retVal = importData.SetMergePoints("", True, 0.001)
                  Debug.Print "  Merge points:      " & retVal
              ' Load the specified DXF/DWG file
                  Dim newDoc As SldWorks.ModelDoc2
                  Set newDoc = swApp.LoadFile4(filename, "", importData, longerrors)
                  retVal = newDoc.Extension.SelectByID2("Model", "SKETCH", 0, 0, 0, False, 4, Nothing, 0)
                  Set Part = swApp.ActiveDoc
                  boolstatus = Part.Extension.SelectByID2("Top Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
                  boolstatus = Part.ChangeSketchPlane()
                  boolstatus = Part.EditRebuild3()
                  'Dim myFeature As SldWorks.Feature
                  boolstatus = Part.Extension.SelectByID2("Model", "SKETCH", 0, 0, 0, False, 4, Nothing, 0)
              Dim myFeature As Object
              Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, 0.00021, 0.01, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, True, True, True, 0, 0, False)
              Hersh
