Hello! I have multiple Microsoft Word '97 documents that have revision letters that automatically change in the document everytime it is opened and something has changed. Well, the company I work for has since upgraded to Word 2010, and the automatic revisions wont update anymore. I know the data card and document are linked because everytime I fill information out in the Data Card, the data on the document changes to what the data card says. Everything changes BUT the revision letter. The file extensions are .doc. I have already tried converting it to a .docm so the macros are enabled, but that still won't work. I don't understand! I have already created a macro.
Heres the code I used:
Sub AutoOpen()
' AutoOpen Macro
' Macro created 7/31/13 by AWHITING
' ActiveDocument.Select
' Selection.WholeStory
' Selection.Fields.Update
' Selection.HomeKey Unit:=wdLine
'End Sub
Dim aStory As Range
Dim aField As Field
For Each aStory In ActiveDocument.StoryRanges
For Each aField In aStory.Fields
aField.Update
Next aField
Next aStory
Thanks!
Andrew,
Try the update with Dispatch. Before the file is checked in change add one to the revision. I am not a word macro expert but that's is where I would start If I wanted to do the same function.
Craig
