0 Replies Latest reply on Jul 31, 2013 6:10 PM by Trevor Wunn
    Solidworks Freezing When Bend Table is Set
    Trevor Wunn
      Hello All,
      So i have a macro that, among other things, sets the gauge table and bend table of a sheet metal part. It was working wonderfully(or so I thought) until this morning. I haven't changed anything in it for at least 3 weeks and I dont have any clue as to how to fix it because I don't know what is wrong. It runs through just fine right up until the code where it is supposed to set the bend table. The little excel table pops up in solidworks and then everything freezes. I tried making a new part and it works just fine, it seems to happen on older parts only(I think). If anyone could take a look at it, it would be very much appreciated as I am seriously stumped.
      Trevor Wunn
      Public Const STOCK_XREF As String = "J:\CP LIBRARY\CP-KRAUSE MATERIAL REFERENCE.xlsx"
      Public Const CP_STEEL As String = "J:\Toolbox\Templates\Drawing Standards\Ga. Tables\CP-STEEL.xls"
      Public Const CP_BEND As String = "J:\Toolbox\Templates\Drawing Standards\Ga. Tables\CP-BEND DEDUCTIONS.xls"
      Public swApp As SldWorks.SldWorks
      Public swModel As SldWorks.ModelDoc2
      Public swFeat As SldWorks.feature
      Public swSubFeat As SldWorks.feature
      Public swSelMgr As SldWorks.SelectionMgr
      Public kStock As String
      Public cpStock As String
      Public cpGauge As String
      Public cpRadius As String
      Public customPropertyMgr As SldWorks.CustomPropertyManager
      Public boolStatus As Boolean
      Public component As SldWorks.Component2
      Option Explicit
      Public gaugeTable As String
      Sub Main()
      Set swModel = swApp.ActiveDoc
      Set swFeat = swModel.FirstFeature
      Set customPropertyMgr = swModel.Extension.CustomPropertyManager("")
      'get kstocknumber
      kStock = swModel.GetCustomInfoValue("", "kstockNumber")
      'check to make sure the stock number is correct
      If IsNumeric(Right(kStock, 1)) = False Then
          MsgBox ("Double Check the Stock Number")
          End
      'figure out what stock number/material needs to be used
      If swModel.GetType = 1 Then
      '    Stock_Convert
      cpStock = swModel.GetCustomInfoValue("", "MaterialPartNo")
          Gauge_Table
      'Select Base Flange
          Do While Not swFeat Is Nothing
              Select Case swFeat.GetTypeName
                  Case "SheetMetal"
                      Process_SheetMetal swApp, swModel, swFeat
                  Case "SMBaseFlange"
                      Process_SMBaseFlange swApp, swModel, swFeat
                  Case "EdgeFlange"
                      Process_EdgeFlange swApp, swModel, swFeat
              End Select
              Set swFeat = swFeat.GetNextFeature
          Loop
      Else
          MsgBox "Can only be used on parts, not assemblies"
          End
      Function Stock_Convert()
      Dim myExcelApp As Object
      Dim xlSheet As Variant
      'Open excel workbook
      Set myExcelApp = CreateObject("Excel.Application")
      myExcelApp.Visible = False
      myExcelApp.WorkBooks.Open FileName:=STOCK_XREF
      'get cpStock from .xls file
      Set xlSheet = myExcelApp.ActiveSheet
      Dim y As Double
      y = 1
      Do While xlSheet.Cells(y, 1) <> kStock
          If xlSheet.Cells(y, 1) <> kStock Then
              y = y + 1
      Loop
      cpStock = xlSheet.Cells(y, 2)
      myExcelApp.WorkBooks.Close
      End Function
      Function Gauge_Table()
      Dim y As Double
      'Figure out which gauge to use
      myExcelApp.WorkBooks.Open FileName:=CP_STEEL
      y = 1
      Do While xlSheet.Cells(y, 4) <> cpStock
          If xlSheet.Cells(y, 4) <> cpStock Then
              y = y + 1
      Loop
      cpGauge = xlSheet.Cells(y, 1)
      End Function
      Sub Process_SMBaseFlange _
      ( _
          swApp As SldWorks.SldWorks, _
          swModel As SldWorks.ModelDoc2, _
          swFeat As SldWorks.feature _
      'set gauge table parameters
          Debug.Print "  +" & swFeat.Name & " [" & swFeat.GetTypeName & "]"
      Dim swBaseFlange As SldWorks.BaseFlangeFeatureData
      Set swBaseFlange = swFeat.GetDefinition()
          swBaseFlange.UseGaugeTable = True
          swBaseFlange.GaugeTablePath = CP_STEEL
          swBaseFlange.ThicknessTableName = cpGauge
          boolStatus = swFeat.ModifyDefinition(swBaseFlange, swModel, component)
          Debug.Print "   Gauge Table = " & swBaseFlange.GaugeTablePath
          Debug.Print "   Thickness = " & swBaseFlange.Thickness / 0.0254
          Debug.Print "   ThicknessName = " & swBaseFlange.ThicknessTableName
          Debug.Print "   Used Gauge Table = " & swBaseFlange.UseGaugeTable
      'set sheet metal properties
      Sub Process_SheetMetal _
      ( _
      Dim swSheetMetal As SldWorks.SheetMetalFeatureData
      Set swSheetMetal = swFeat.GetDefinition
      Dim swCustBend As SldWorks.customBendallowance
      Set swCustBend = swSheetMetal.GetCustomBendAllowance
      Process_CustomBendAllowance swApp, swModel, swCustBend, swSheetMetal, swFeat
      'set sheet metal bend allowances
      Sub Process_CustomBendAllowance _
      ( _
          swCustBend As SldWorks.customBendallowance, _
          swSheetMetal As SldWorks.SheetMetalFeatureData, _
      swCustBend.BendTableFile = CP_BEND
      swCustBend.Type = 1
      Debug.Print "Bend Allowance = " & swCustBend.BendAllowance
      Debug.Print "Bend Deduction = " & swCustBend.BendDeduction
      Debug.Print "Kfactor = " & swCustBend.KFactor
      Debug.Print "   Bend type = " & swCustBend.Type
      Debug.Print "   BendTable File = " & swCustBend.BendTableFile
      Call swSheetMetal.SetCustomBendAllowance(swCustBend)
      boolStatus = swFeat.ModifyDefinition(swSheetMetal, swModel, component)
      Sub Process_EdgeFlange _
      ( _
      Dim swEdgeFlange As SldWorks.EdgeFlangeFeatureData
      Set swEdgeFlange = swFeat.GetDefinition()
      Dim swCustBend As customBendallowance
      Set swCustBend = swEdgeFlange.GetCustomBendAllowance
      swEdgeFlange.UseDefaultBendRadius = True
      swCustBend.Type = 1
      Call swEdgeFlange.SetCustomBendAllowance(swCustBend)
      boolStatus = swFeat.ModifyDefinition(swEdgeFlange, swModel, component)
