5 Replies Latest reply on Jul 31, 2014 5:01 AM by Yong Ning
    Using quick filter in open file dialog?
    David Watkins
      Is there a way to add the quick filter for parts, assemblies and drawings to the open file dialog? I am using the GetOpenFileName call and can add the filters in there for them but it would be better if I can have the quick filter also. Is this available?
      David
        • Re: Using quick filter in open file dialog?
          Deepak Gupta
          Check the Open File Example (VBA)  in the SW API Help files.
              David Watkins
              Deepak,
              I am looking for the quick filter buttons that were added in SW 2013 .
              David
                Yong Ning
                thanks your link web.
                follow code, can be open file from folder
                'how to prompt the user for the name of the file to open. This example also shows how to set up filters by file types.
                ' Preconditions: Open the Immediate window.
                ' Postconditions:
                ' 1. The File to Attach dialog is displayed and the file
                '    types specified in the filter are listed.
                ' 2. Examine the Immediate window to verify that the
                '    name of the file you selected matches what the name
                '    of the printed to the Immediate window.
                Private Sub OpenDocument()
                   'SolidWorks Forums: Using quick filter in open file dialog?
                   ''https://forum.solidworks.com/message/442407#442407
                  Dim T: T = Timer
                  Dim Path, FileName, Filter
                  Dim fileConfig As String, fileDispName As String, fileOptions As Long
                    Dim SwApp As SldWorks.SldWorks, SwDraw As DrawingDoc
                    Set SwApp = GetObject(, "SldWorks.Application")
                    Filter = "SolidWorks Files (*.sldprt; *.sldasm; *.slddrw)|*.sldprt;*.sldasm;*.slddrw|Filter name (*.fil)|*.fil|All Files (*.*)|*.*|"
                    FileName = SwApp.GetOpenFileName("File to Attach", "", Filter, fileOptions, fileConfig, fileDispName)
                    Set SwDraw = SwOpenFile(SwApp, FileName)
                    Debug.Print SwDraw.GetPathName
                  Timing T
                Function Timing(T)
                    Dim ss, h, m
                    ss = Timer - T
                    h = Int(ss / 3600)
                    m = Int((ss Mod 3600) / 60)
                    ss = Int(ss Mod 60)
                    Debug.Print h & "时:" & m & "分:" & ss & "秒"
                    MsgBox h & "时:" & m & "分:" & ss & "秒"
                End Function
                ''返回装配体中所有零件和子装配体的实体名。
                Function SwOpenFile(SwApp, OpenFile)
                    'Debug.Print OpenFile
                '    SwApp.Visible = True
                    Dim SwModel             As Object
                    Dim nDocType            As Long
                    Dim nErrors             As Long
                    Dim nWarnings           As Long
                    Dim swOpenDocOptions_Silent
                    swOpenDocOptions_Silent = 1
                    ' Determine type of SolidWorks file based on file extension
                    If InStr(LCase(OpenFile), "sldprt") > 0 Then
                        nDocType = 1 'swDocPART
                    ElseIf InStr(LCase(OpenFile), "sldasm") > 0 Then
                        nDocType = 2 'swDocASSEMBLY
                    ElseIf InStr(LCase(OpenFile), "slddrw") > 0 Then
                        nDocType = 3 'swDocDRAWING
                    Else
                        ' Probably not a SolidWorks file...
                        nDocType = swDocNONE
                        '...so the file cannot be opened
                        Exit Function
                    Set SwModel = SwApp.OpenDoc6(OpenFile, nDocType, _
                                    swOpenDocOptions_Silent, "", nErrors, nWarnings)
                    'SwApp.Visible = True
                    Set SwOpenFile = SwModel
                    'Debug.Print SwModel.GetPathName
                End Function
