So, you may have noticed that SolidWorks 2013 is now doing some strange things when it comes to 'keeping models in memory' even if you close all of the files you have open. It seems like SWX doesn't quite let everything go, resulting in strange warnings when you open more files ('File xxxx is already opened, whould like to use this already opened file?, file references magically pointing to the wrong folders, etc). In addition, ever notice how SWX just takes a lot of memory to run? Well, here's a little code that takes care of these issues:
Private Sub flushmemory()
Try
GC.Collect()
GC.WaitForPendingFinalizers()
If (System.Environment.OSVersion.Platform = PlatformID.Win32NT) Then
Dim myProcesses As Process() = Process.GetProcessesByName("SLDWORKS")
Dim myProcess As Process
For Each myProcess In myProcesses
SetProcessWorkingSetSize(myProcess.Handle, -1, -1)
Next
Catch ex As Exception
End Try
Private Declare Auto Function SetProcessWorkingSetSize Lib "kernel32.dll" (ByVal procHandle As IntPtr, ByVal min As Int32, ByVal max As Int32) As Boolean
Function sldOnIdle() As Integer
If openDocs.Count = 0 AndAlso idleFlag Then
Dim workDir As String = iSwApp.GetCurrentWorkingDirectory()
idleFlag = False
flushmemory()
iSwApp.SetCurrentWorkingDirectory(workDir)
End Function
Note that I have this code in an add-in that is always 'listening' to solidworks, so you would have to add the appropriate handlers, etc. But, this takes care of the 'files in memory' problems and also make solidworks a little less memory-intensive
Enjoy!
Jason
