14 Replies Latest reply on Aug 30, 2013 3:30 AM by Oleg Bezyaev
    Light geometry
    Oleg Bezyaev
      Is there some sort of way to create sketch geometry without visibility to the user and not resource intensive?
      For example, to draw a line so that it will not appear on the screen and when it was available all of its parameters (StartPoint, EndPoint ...)
        • Re: Light geometry
          Artem Taturevych
          Use ICurve interface which is the definition of sketch segments.
              Oleg Bezyaev
              Modeler swModeler = (Modeler)SwApp.GetModeler(); //not null
              ICurve myCurve2 = (ICurve)swModel.CreateLine2(0D, 0D, 0D, 1D, 0D, 0D); //return null
                  Artem Taturevych
                  Hi Oleg,
                  Here is the C# sample:
                  static ICurve CreateLine(IModeler modeler, double[] startPoint, double[] endPoint)
                      double[] dir = new double[] { endPoint[0] - startPoint[0],
                                                    endPoint[1] - startPoint[1],
                                                    endPoint[2] - startPoint[2]};
                      ICurve curve = modeler.CreateLine(startPoint, endPoint) as ICurve;
                      if (curve != null)
                      return curve.CreateTrimmedCurve2(startPoint[0], startPoint[1], startPoint[2],
                  endPoint[0], endPoint[1], endPoint[2]);
                  static void Main(string[] args)
                      ISldWorks app = Activator.CreateInstance<SldWorksClass>();
                      if (app != null)
                          ICurve curve = CreateLine(app.IGetModeler(), new double[] { 0, 0, 0 }, new double[] { 1, 0, 0 });
                          System.Diagnostics.Debug.Assert(curve != null);
                          //get line params
                          double[] lineParams = curve.LineParams as double[];
                          double start;
                          double end;
                          bool isClosed;
                          bool isPeriodic;
                          curve.GetEndParams(out start, out end, out isClosed, out isPeriodic);
                          double[] evalData = curve.Evaluate2(start, 1) as double[];
                          //evalData[0]...evalData[2] - evaluated point
                          //evalData[3]...evalData[5] - evaluated derivative 1 (tangent vector)
                  ____________________________________________________
                  Regards,
                  Artem Taturevych, Application Engineer at Intercad (Australia)
                  translationXpert – add-in to translate SolidWorks models
                  myIntercad an integrated tool for SolidWorks Professionals
                  LinkedIn SolidWorks API Education Group
                      Oleg Bezyaev
                      I missed CreateTrimmedCurve2
                      Thank you, Artem!
                        Oleg Bezyaev
                        Hi Artem,
                        can you help me again?
                        myCenter.ArrayData[0] = 0.0000023202759685468531
                        myCenter.ArrayData[0] = 0.0000065053843365034717
                        myCenter.ArrayData[0] = 0.0000041851083679566182
                        firstVector.ArrayData[0] = 1.0
                        firstVector.ArrayData[0] = 0
                        1. private double[] GetPoint(IBody2 myBody, MathPoint myCenter, MathVector firstVector)
                        2.         {
                        3.             double[] pointOnEdge;
                        4.             Face2[] swFaceArr = new Face2[1];
                        5.             Face2 swFace = (Face2)myBody.GetFirstFace();
                        6.
                        7.             while ((null != swFace))
                        8.             {
                        9.                 Loop2 myLoop = swFace.GetFirstLoop();
                        10.                 if (myLoop.IsOuter())
                        11.                 {
                        12.                     object[] myEdjes = myLoop.GetEdges();
                        13.                     IEdge[] myEdjes1 = Array.ConvertAll<object, IEdge>((object[])myEdjes, delegate(object obj) { return obj as IEdge; });
                        14.                     foreach (IEdge myEdje in myEdjes1)
                        15.                     {
                        16.                         ICurve myCurve = myEdje.GetCurve();
                        17.
                        18.                         ICurve curve = CreateLine(SwApp.IGetModeler(), new double[] { myCenter.ArrayData[0], myCenter.ArrayData[1], myCenter.ArrayData[2] },
                        19.        new double[] { firstVector.ArrayData[0], firstVector.ArrayData[1], firstVector.ArrayData[2] });
                        20.
                        21.
                        22.                         double[] lineParams = curve.LineParams as double[];//NullReferenceException
                        23.                         object myPoint = myCurve.IntersectCurve(curve, myEdje.GetStartVertex().GetPoint(), myEdje.GetEndVertex().GetPoint(), new double[] { lineParams[0], lineParams[1], lineParams[2] },
                        24.        new double[] { lineParams[3], lineParams[4], lineParams[5] });
                        25.                         Type UUU = myPoint.GetType();
                        26.                         if (UUU.Name != "DBNull"
                        27.                         {
                        28.                             return pointOnEdge = (double[])myPoint;
                        29.                         }
                        30.                     }
                        31.                     myLoop.GetNext();
                        32.                 }
                        33.                 swFace = (Face2)swFace.GetNextFace();
                        34.             }
                        35.             return null
                        36.         }
                        37.
                        38.         static ICurve CreateLine(IModeler modeler, double[] startPoint, double[] endPoint)
                        39.         {
                        40.             double[] dir = new double[] { endPoint[0] - startPoint[0],
                        41.                                   endPoint[1] - startPoint[1],
                        42.                                   endPoint[2] - startPoint[2]};
                        43.             ICurve curve = modeler.CreateLine(startPoint, endPoint) as ICurve;
                        44.             if (curve != null
                        45.             {
                        46.             }
                        47.             ICurve myCurve = curve.CreateTrimmedCurve2(startPoint[0], startPoint[1], startPoint[2],
                        48.         endPoint[0], endPoint[1], endPoint[2]);//return null
                        49.             ICurve myCurve1 = curve.CreateTrimmedCurve2(startPoint[0], startPoint[1], startPoint[2],
                        50.             dir[0], dir[1], dir[2]);//return null
                        51.             return myCurve;
                        52.         }
                      Oleg Bezyaev
                      Is there any simple examples? Please
                      Simon Turner
                      I use SketchManager::AddToDB and DisplayWhenAdded.
