2 Replies Latest reply on Sep 18, 2013 5:00 AM by Yong Ning
    How to judge  Is Feature Suppressed ?
    Yong Ning
      Sub ll()
        Dim SwModel As ModelDoc2, SwFeat As Feature
        Set SwModel = Application.SldWorks.ActiveDoc
        Set SwFeat = SwModel.FirstFeature
        Do While Not SwFeat Is Nothing
          Debug.Print SwFeat.Name, SwFeat.GetTypeName
      How to  jedge select Feature
      Featur Suppressed
           or
      Featire unSuppressed
          Set SwFeat = SwFeat.GetNextFeature
        Loop
        • Re: How to judge  Is Feature Suppressed ?
          Artem Taturevych
          In your case this is the component but not feature (you can cast to feature). Here is the example:
              Set swModel = swApp.ActiveDoc
              Set swAssy = swModel
              Set swComp = swSelMgr.GetSelectedObjectsComponent(1)
              If swComp.GetSuppression() = swComponentSuppressionState_e.swComponentResolved _
                  Or swComp.GetSuppression() = swComponentSuppressionState_e.swComponentFullyResolved Then
                  MsgBox "Not Suppressed"
              Else
                  MsgBox "Suppressed"
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
              Yong Ning
              Thank your code.
              your code is need code for me.
              Private Sub fdsafdsafdsa()
                Dim swModel As ModelDoc2, swFeat As Feature, vModel As ModelDoc2
                Set swModel = Application.SldWorks.ActiveDoc
                Dim SwSelMgr As SelectionMgr, SwComp As Component2
                Dim SelArray(1 To 1)
                Set SwSelMgr = swModel.SelectionManager
                Set swFeat = swModel.FirstFeature
                Do While Not swFeat Is Nothing
                  If swFeat.GetTypeName = "Reference" Then '
                    swFeat.Select False
                    'Set SwComp = SwSelMgr.GetSelectedObjectsComponent(1)
                    If UCase(swFeat.name) Like "*VOLUME*" Then
                      Debug.Print swFeat.name & "  Need Suppressed"
                      swModel.EditSuppress
                  Set swFeat = swFeat.GetNextFeature
                Loop
              Sub TraverCompFeat()
                    swFeat.Select False
                    If SwComp.GetSuppression() < 2 Or SwComp.GetSuppression() > 3 Then
                      Debug.Print swFeat.name & " Suppressed"
                      SwComp.SetSuppression2 3
                Loop
