Hello everyone
I would like to know please, if it possible to create a graph showing the Lift Force for various AOA of different speed.
You can see an example in the very professional drawing I did.
Hello everyone
Is there any helpful link where I can read about how to do the parameter study? Otherwise I have to go with with the excel spreadsheet but it won't be what I need, as I'm looking for an optimum result between two Goals and not just to produce a graph.
if you're using 2013, there are some discussions about it in the help which i find useful.
we also posted this on our blog recently: http://www.hawkridgesys.com/blog/flow-simulation-2013-parametric-studies/
can you elaborate on this new requirement: "as I'm looking for an optimum result between two Goals and not just to produce a graph."
the software does have an option for a parametric optimization based on a goal. but if you're going that direction, why would you need the curves?
2013, parameter study will get you close.
Otherwise, run the studies, batch output the results. Put them in a spreadsheet and plot in excel.
