Hi
Could anyone tell me where i'm going wrong. I have tried to do the basic motion study on the attached assembly but it is failing. I have done all the mating for all the components including the geneva mechanism parts and constraint the components but it keep on giving me this messange "3D Contacts in Basic Motion are not compatible with certain SolidWorks features, including component patterns, advanced mates, and mechanical mates, and you may experience incorrect results."
Could anyone just check on my attached assembly and correct me where i went wrong.
On my mobile so can't look at the files.
Do you have those elements? If so, remove them and try again. If the assembly doesn't move when you drag it, motion isn't going to work. Remember that if you're using contact, remove the mates if they also exist. For example, gear mates don't need to exist if you use contact between the teeth.
Do you have solidworks motion? Turn it on and try that solver.
