When im creating a tooling split it gives me an error saying it cannot knit the surfaces together. how do i fix this? I can't upload any pictures though.
Manual troubleshoot for your problem:
1. Make a copy of the parting surface body
2. Try to knit the parting surface with the core surface. Does the knit command work? Are there any gaps or other problems?
3. Try to knit the parting surface with the cavity surface. Does the knit command work? Are there any gaps or other problems?
One trick which sometimes solves the problem is to save the faces of the part that you are trying to knit as an IGES file and then read it back into SolidWorks - it goes through a different algorithm and can create one topological surface.
Another is to buy SplitWorks from R&B - which has a function called Island Analysis showing non-connected faces, which can cause the knit function to fail.
George Berold
R&B
James,
Unfortunately, it is nearly impossible to say why it cannot knit surfaces together without the file of at least some pictures.
If you have any areas where two of the surfaces intersect one another or where two or three surfaces form a T shape, that will kill the Knit.
Jerry S.
