JTJoe Travia26/07/2013
I created this part (see attached) utilizing the Solidworks toolbox. I now need to revise the bore on the part but I can't for the life of me figure out how to edit it because of the equations. I have a few options that I know of:
- recreate the part with the correct bore, but then I have to insert it in to the assembly where the part is used which is a real bother (and there are two different gears with the same issue). plus there are associated drawings that have to be recreated. Or ...
- I could draw a new sketch on top of this part and do an extrude-cut to get what I want but that seems redundant. I'd rather edit the existing bore.
Any help would be appreciated.
Thank you!
Joe
