4 Replies Latest reply on Jul 26, 2013 6:51 PM by Mike Morgan
    Macro to change custom properties of a drawing's referenced part
    Mike Morgan
      I'm trying to create a macro that will do two things: 1) Add a revision to the revision table with a formatted date as the revision number (I have this section working so I have not included it here so it's easier to see my problem section) and 2) change the custom property, "Revision", of the part referenced by the drawing to have that same revision number as its value. I keep getting a run-time error 91 - object not set on the swDrawModel.CustomInfo2 line. How do I make this work? Any help would be much appreciated.
      Dim revnum As String
      Dim swView As SldWorks.View
      Dim swDrawModel As SldWorks.PartDoc
      Dim sModelName As String
      revnum = Format(Date, "YYMMDD")
          Set swModel = swApp.ActiveDoc
          Set swView = swSelMgr.GetSelectedObject5(1)
         Set swDrawModel = swView.ReferencedDocument
          swDrawModel.CustomInfo2("", "Revision") = revnum
