I am having a problem with my fit spline command with the "Select Chain" option causing Solidworks to stop working. Below is a picture of what I am trying to create the fit spline on (highlighted section):
My fit spline seems to be working on everything else, but when I try it on this section, it starts working fine, then slows down along the path, then it just stops going and I am left with my mouse cursor as the right click for green check mark image. No matter where I move my mouse, it stays as that image and I have to go to the task manager and end Solidworks. I'm guessing it is just because the spline is so complicated, but that shouldn't be a problem for a program as powerful as Solidworks. Anyways, any help on the matter would be appreciated. Thanks.
Chris V
What are your computer system specs?
Any chance you can post your file for us to try? Use the Advanced Editor link in the upper right of the dialog box.
Cheers,
Anna
