Yesterday I tried to switch from SW2012 to SW2013
Doing the installation with de disc from SW, everything seem to be normal.
And after the installation i tried to open the SW2013, and There was a problem with the lincese
so I called my VAR today, but they told me that we don't have a subscription (that is true).
So the license I had for SW2013 expired and I can no longer install it.
So is this correct?,
Someone in here without the subscription install SW2013 without problems?
Your license does not expire, regardless of whether or not you are on subscription. If your subscription was valid when 2013 was released, then you are entitled to use it. If, however, your subscription expired before 2013 was released, then your license does not entitle you to use 2013, so it will not work.
