4 Replies Latest reply on Jul 26, 2013 12:56 AM by Oleg Bezyaev
    Rotate vector with API
    Oleg Bezyaev
      Is there any way to using SW API to turn the vector moment of inertia at a certain angle in a certain plane? For example, turn mathematically (not model) axis "Ix" at an angle of 2 degrees in the plane "IxIy".
        • Re: Rotate vector with API
          Artem Taturevych
          Yes, it is possible to do using the MathUtility::CreateTransformRotateAxis method to get the transformation and then apply this transformation to your original vector MathVector::MultiplyTransform.
          Function CreateTransformRotateAxis( _
             ByVal PointObjIn As Object, _
             ByVal VectorObjIn As Object, _
             ByVal Angle As Double _
          ) As Object
          PointObjIn - any point lies on your vector (Ix) you want to rotate
          VectorObjIn - vector to rotate about. If your plane is IxIy, your rotation vector is normal to IxIy.
          Angle - angle in radians
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
              Oleg Bezyaev
              I've already tried that.
              firstVector - (1,0,0)
              angle = 1
              MathTransform myNewTransform = swMathUtil.CreateTransformRotateAxis (mycenterOfMass, firstVector, angle * (Math.PI / 180.0));
              firstVector.MultiplyTransform (myNewTransform);
              after transformations firstVector ArrayData was equal to (1,0,0)
                Oleg Bezyaev
                If by VectorObjIn mean vector  Iz for the plane IxIy - the result is the same))  Vector firstVector stayed (1,0,0)
                  Oleg Bezyaev
                  I figured out
                  Was:
                  MathTransform myNewTransform = swMathUtil.CreateTransformRotateAxis(mycenterOfMass, thirdVextor, angle * (Math.PI / 180.0));
                  firstVector.MultiplyTransform(myNewTransform);
                  secondVector.MultiplyTransform(myNewTransform);
                  After:
                  firstVector = firstVector.MultiplyTransform(myNewTransform);
                  secondVector = secondVector.MultiplyTransform(myNewTransform);
