I'm hearing that you can display your 3D cad assembly from solidworks into Labview.
The posts below mostly suggest a .stl file which is a single file format not an assembly.
I didn't understand the procedure to do this. Any suggestions?
https://decibel.ni.com/content/docs/DOC-17358
http://digital.ni.com/public.nsf/allkb/CCE3C1DC149C3A35862574B800734FB4
http://forums.ni.com/t5/LabVIEW/SolidWorks-Import/td-p/915990
http://forums.ni.com/t5/LabVIEW/Which-kind-3D-format-file-can-be-used-by-LV/td-p/1530510
We figured out how to make this work. I thought I share the findings.
1. Keep your assembly small. Large formats almost don't work 500MB or less
2.Export your assembly to a STL ASCII format.
Attached picture shows STL settings in Solidworks
2. Load STL file into 3D graphic view of VI.
Works just great.
