I am just starting to use decals. I have pasted a decal on the side of a cylinder and it sits fine. Problem is it also shows on the opposite side of the cylinder. See the pics below. There must be a setting I am missing. This one actually is pretty unobtrussive but others have shown with the mirror immage of the decal on the back side of the vessel. Any suggestions?
Stephen,
I don't think it is a setting you are missing. If I remember correctly you will need to split the cylinder's faces using the "Split Line" command to break it up into halves most likely. As you can see in the sample image here, you don't get the artifact on the back side:
Paul
