2 Replies Latest reply on Aug 22, 2013 9:50 AM by Yong Ning
    How to delete the equation at the specified index
    Yong Ning
      Hope delete select 1,2,4 Item Equation
      record Macro ,the code is
        Set Part = swApp.ActiveDoc
        Set SelMgr = Part.SelectionManager
        boolstatus = Part.Extension.SelectByID2("Equations", "EQNFOLDER", 0, 0, 0, False, 0, Nothing, 0)
        Part.DeleteAllRelations
      The Code result is
      2013 SolidWorks API Help - Pack and Go Part and Linked Equation (VBA)
      http://help.solidworks.com/2013/English/api/sldworksapi/pack_and_go_part_and_linked_equation_example_vb.htm
      2013 SolidWorks API Help - Add Equation and Evaluate All Example (VBA)
      http://help.solidworks.com/2013/English/api/sldworksapi/add_equation_and_evaluate_all_example_vb.htm
      2013 SolidWorks API Help - Use IIf Function When Adding an Equation Example (VBA)
      http://help.solidworks.com/2013/English/api/sldworksapi/use_iif_function_when_adding_an_equation_example_vb.htm
      2013 SolidWorks API Help - Automatically Solve Equations in Sequence (VBA)
      http://help.solidworks.com/2013/English/api/sldworksapi/automatically_solve_equations_in_sequence_example_vb.htm
      SolidWorks Forums: Does SolidWorks have APIs that can modify the values of global variables in SolidWorks equations?
      https://forum.solidworks.com/message/330406#330406
        • Re: How to delete the equation at the specified index
          Artem Taturevych
          Use this method: http://help.solidworks.com/2013/English/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.IEquationMgr~Delete.html
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
              Yong Ning
              Thank you tips
              Sub ll()
                Dim SwModel As ModelDoc2
                Set SwModel = Application.SldWorks.ActiveDoc
                Dim SwEqgMgr As EquationMgr
                Set SwEqgMgr = SwModel.GetEquationMgr
                With SwEqgMgr
                  '.Equation(0) = "x=" & 2
                  For ii = 0 To .GetCount - 1
                    Debug.Print .Equation(ii)
                    .Delete (ii)
                  Next ii
                End With
              Use IIf Function When Adding an Equation Example (VB)
              This example shows how to use the Visual Basic IIf function when adding an equation.
              ' Preconditions: Model document is open, feature dimensions are visible, and at least
              '                one equation already exists.
              ' Postconditions: An equation that uses the Visual IIf function is added.
              Option Explicit
                  Dim swApp                   As SldWorks.SldWorks
                  Dim swModel                 As SldWorks.ModelDoc2
                  Dim swEqnMgr                As SldWorks.EquationMgr
                  Dim i                       As Long
                  Dim nCount                  As Long
                  Dim bRet                    As Boolean
                  Set swModel = swApp.ActiveDoc
                  Set swEqnMgr = swModel.GetEquationMgr
                  Debug.Print "File = " & swModel.GetPathName
                  Debug.Print "  Status = " & swEqnMgr.Status
                  nCount = swEqnMgr.GetCount
                  ' List the existing equations and their calculated values
                  For i = 0 To nCount - 1
                      Debug.Print "  Eqn(" & i & ")  = " & swEqnMgr.Equation(i)
                      Debug.Print "    Value  = " & swEqnMgr.Value(i)
                  Next i
                 ' Add an equation that uses the Visual Basic IIf function,
                 ' list it and its calculated value
                  swEqnMgr.Add i, ("""D1@Extrude2"" = (IIf(""D1@Extrude3"">20, 15, 6))+3")
              Sub ll()
                Dim oDic
                Set oDic = CreateObject("Scripting.Dictionary")
                Dim SwModel As ModelDoc2, SwRootComp As Component2, SwComp As Component2
                Dim SwRootConf As Configuration, vChildComp, vModel As ModelDoc2
                Set SwRootConf = SwModel.GetActiveConfiguration
                Set SwRootComp = SwRootConf.GetRootComponent
                vChildComp = SwRootComp.GetChildren
                For ii = 0 To UBound(vChildComp)
                   Set SwComp = vChildComp(ii)
                   Set oDic(Left(SwComp.Name2, Len(SwComp.Name) - 2)) = SwComp.GetModelDoc
                Next ii
                Dim Arr
                Arr = oDic.Items
                For ii = 0 To UBound(Arr)
                  TravseEquition Arr(ii)
                Next ii
              Function TravseEquition(SwModel) ' As ModelDoc2)
                 Dim SwEqMgr As EquationMgr
                 Set SwEqMgr = SwModel.GetEquationMgr
                 For ii = 0 To SwEqMgr.GetCount - 1
                   Debug.Print SwModel.GetTitle,
                   Debug.Print SwEqMgr.Equation(ii)
                 Next ii
                 Debug.Print "**************"
              End Function
              Private Sub changeEquation()
                Dim oDic, ii, Arr, oArr, rArr
                Dim cArr(1, 1)
                cArr(0, 0) = "cccc": cArr(0, 1) = "aaaa"
                cArr(1, 0) = "bbbb": cArr(1, 1) = "aaaa"
                Dim SwModel As ModelDoc2, swRootComp As Component2, swComp As Component2
                Arr = ComponentArr(SwModel)
                nn = UBound(Arr)
                  'Debug.Print "*********"
                  If UCase(Arr(ii).GetTitle) Like "*SLDASM" Then
                    Set vModel = Arr(ii)
                    oArr = ComponentArr(vModel)
                    Debug.Print "***************"
                    If Not IsEmpty(oArr) Then
                       For jj = 0 To UBound(oArr)
                          'Debug.Print Space(6) & oArr(jj).GetTitle
                          If Not IsEmpty(oArr(jj)) Then
                            Set vModel = oArr(jj)
                            ChangeEquationArr vModel, cArr
                       Next jj
                  Else
                    'Debug.Print Space(2) & Arr(ii).GetTitle
                Next ii
                SwModel.ForceRebuild3 True
              Function ChangeEquationArr(SwModel As ModelDoc2, cArr)
                 Dim SwEqMgr As EquationMgr, Arr(), Arr1, Arr2
                 'Set oDic = CreateObject("Scripting.Dictionary")
                 Dim oDic As New Dictionary
                 With SwEqMgr
                       For jj = 0 To UBound(cArr)
                          .Equation(ii) = Replace(.Equation(ii), cArr(jj, 0), cArr(jj, 1))
                       Next jj
                    Next ii
                 End With
              End Function
              Function ComponentArr(SwModel As ModelDoc2)
                'Debug.Print SwModel.GetTitle
                Dim oDic
                Dim swRootComp As Component2, swComp As Component2
                Set swRootComp = SwRootConf.GetRootComponent
                vChildComp = swRootComp.GetChildren
                   Set swComp = vChildComp(ii)
                   Set vModel = swComp.GetModelDoc
                    If swComp.GetSuppression() = swComponentSuppressionState_e.swComponentResolved _
                      Or swComp.GetSuppression() = swComponentSuppressionState_e.swComponentFullyResolved Then
                        Set oDic(vModel.GetTitle) = vModel
                   'Set oDic(Left(SwComp.Name2, Len(SwComp.Name) - 2)) = SwComp.GetModelDoc
                Next ii
                ComponentArr = oDic.Items
              End Function
