Hi, i couldn't find any relevant information by searching, so here it goes:
I am having problems with "unpacking" STEP files inside the Enterprise PDM vault. It appears the vault has problems handling files that are not moved into it, but rather just "appear" when processing the STEP file. To get around it i unpack it outside the vault, and move the files into the vault afterwards.
So i wonder, have anyone else had any bad experiences with processing STEP files inside the vault?
.....and knows why?
.....and knows how to remedy this?
.....and knows if the error applies to other files, including parasolids?
I'm sorry i don't have any specific error description, it's been a long time since i troubleshot this, but the need for a solution has surfaced again. I'm really just hoping someone has any experience with this and can point me in the right direction.
Best regards,
Martin
Martin, I created a workflow today that will allow the .step file to be checked into the fault in a vaulted state. We use the step file to send to machine shops that require them and generate them when the drawing goes to a released state. If you wanted to upack the step file just check it out and open it with solidworks. There is no need to unpack it inside the vault.
Hope this helps
Jeff Thomas
Seanic Ocean Systems
