1 Reply Latest reply on Jul 24, 2013 11:27 AM by Greg Johnson
    Entities Property (IDisplayStateSetting)
    Greg Johnson
      The Entities Property is looking for an array of components which is easy to get in an assembly file using the following code:
      Dim blnTopLevelOnly As Boolean = True 'Controls whether program works on all levels of the assembly
      Dim lstComponent As Component2() = New Component2(swAssemblydoc.GetComponentCount(blnTopLevelOnly) - 1) {}
      Dim objComponents() As Object = swAssemblydoc.GetComponents(blnTopLevelOnly)
      For i = 0 To objComponents.GetUpperBound(0)
          Dim swComponent As Component2 = objComponents(i)
          If Not swComponent.IsHidden(True) And Not swComponent.IsSuppressed Then
              lstComponent(i) = swComponent
          If swComponent.GetSuppression = swComponentSuppressionState_e.swComponentLightweight Then
      Next
      swModelDoc.ClearSelection2(True)
      swAssemblydoc.EditAssembly()
      Dim lstComponents As Object = lstComponent
      Dim swDisplayStateSetting As DisplayStateSetting = swModelDocExt.GetDisplayStateSetting(swDisplayStateOpts_e.swSpecifyDisplayState)
      Dim strDisplayStateNames As String() = New String(1) {}
      strDisplayStateNames(0) = strDisplayStateName
      Dim lstDisplayStateNames As Object = strDisplayStateNames
      swDisplayStateSetting.Names = lstDisplayStateNames
      swDisplayStateSetting.Entities = lstComponents
      swDisplayStateSetting.Option = swDisplayStateOpts_e.swSpecifyDisplayState
      swDisplayStateSetting.PartLevel = False
      swDisplayStateSetting.RemoveAppearance = False
      My question is how do I populate lstComponents when I'm working with a part file.
      I'm trying to write a macro that creates a new display state, and then changes the color of that display state to a specified color in a part file. The original display state must remain the original display state color.
