Hi everybody,
Is it ossible to introduce in SolidWorks Flow simulation a time dependency for valves (inseide the boundaries) to open and close in order to direct the flow from one direction to another?
Detailed, the problem is the following:
There is a box with 2 (two) entances and 2 (two) exits and I´m trying to apply in solidworks flow simulation a time dependency in which the inlet flow changes from one entrance to another and, at the same time change the outlet exit too.
Could somebody clearify me if this is duable and if not, if there is another solution?
Appreciated,
Paulo
I don't think the software will let you go with a zero flow to shut it off. You could try a really high pressure. The one thing I'm pretty sure of is that you can't tell it to enable and disable them which is really what you need. Same thing goes for like a porous medium that gets really restrictive.
