26 Replies Latest reply on Jul 31, 2013 3:46 PM by Greg Johnson
    Accessing the drawing number thru VBA
    Jason Wilger
      I am looking to save files as TIF files. I have the macro for that part working, but the macro saves as the model name, not the Dwg No property, which are different. I have changed the macro to match some of the other discussions, but I am just getting errors. Any help would be great. This is the macro I currently have:
      Dim Feature As Object
      Dim swSheet As SldWorks.Sheet
      Dim bRet As Boolean
      Dim i As Long
      Dim vSheetProps As Variant
      Const swTiffPrintScaleToFit As Long = 28
      Const swTiffScreenOrPrintCapture As Long = 6
      Const swTiffImageType As Long = 7
      Const swTiffCompressionScheme As Long = 8
      Const swTiffPrintDPI As Long = 9
      Const swTiffPrintPaperSize As Long = 10
      Set swModel = swApp.ActiveDoc
      f = "C:\SOLIDWORKS COMPONENTS\New folder\"
      Debug.Print "PrintScaleToFit        = " + Str(swApp.SetUserPreferenceToggle(swUserPreferenceToggle_e.swTiffPrintScaleToFit, True))
      Debug.Print "ScreenOrPrintCapture   = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffScreenOrPrintCapture, 1))
      Debug.Print "allorcurrentsheet      = " + Str(swApp.SetUserPreferenceIntegerValue(swallorcurrentsheet, 1))
      Debug.Print "ImageType              = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffImageType, 0))
      Debug.Print "CompressionScheme      = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffCompressionScheme, 2))
      Debug.Print "PrintDPI               = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffPrintDPI, 200))
      Debug.Print "PrintPaperSize         = " + Str(swApp.GetUserPreferenceIntegerValue(swTiffPrintPaperSize))
      file = Dir(f)
          Do While file <> ""
          filen = f + file
          namelength = Len(filen)
          filetype = Mid(filen, (namelength - 5), 7)
          namelength1 = Len(file)
          filename1 = Mid(file, 1, (namelength1 - 7))
          Debug.Print file
          Debug.Print filename1
          lcasefiletype = LCase(filetype)
              If lcasefiletype = "slddrw" Then
                      Set Part = swApp.OpenDoc6(filen, 3, 0, "", longstatus, longwarnings)
                      swApp.OpenDoc6 filen, 3, 0, "", longstatus, longwarnings
                      Set swDraw = swModel
                              bRet = swDraw.ActivateSheet("Sheet1")
                              Set swSheet = swDraw.GetCurrentSheet
                              vSheetProps = swSheet.GetProperties
          Debug.Print "  TemplateName              = " & swSheet.GetTemplateName
          Debug.Print "  PaperSize                 = " & vSheetProps(0)
          Debug.Print "PrintPaperSize         = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffPrintPaperSize, vSheetProps(0)))
                              Part.SaveAs2 f + filename1 & ".TIF", 0, True, False
                      Set Part = Nothing
                      swApp.CloseDoc f + file
              Else
          file = Dir()
      Loop
        • Re: Accessing the drawing number thru VBA
          Keith Hooks
          You can use ModelDocExtension to get a CustomPropertyManager.  With that, you can access any of the documents properites.  I'm not working in VB, but here's the way I do it in C#.  Just replace Revision with the name of your custom property name.
          public static string getDocRevisionProperty(ModelDoc2 swModelDoc)
                      ModelDocExtension swModelDocExt = default(ModelDocExtension);
                      CustomPropertyManager swCustProp = default(CustomPropertyManager);
                      string val = "";
                      string valout = "";
                      bool status;
                      swModelDocExt = swModelDoc.Extension;
                      swCustProp = swModelDocExt.get_CustomPropertyManager("");
                      status = swCustProp.Get4("Revision", false, out val, out valout);  //pass the val, valout by reference
                      return val;
              Jason Wilger
              I need the PRPSHEET:"Dwg No" to be the value accessed. I can get it to work if I use a value in the properties of the drawing, but I need the properties of the assembly / part. I can't seem to get it to accept the syntax for the text previous.
                  Greg Johnson
                  Add this code...
                  dim swModelDoc as SldWorks.ModelDoc2
                  Dim swModelDocExt as SldWorks.ModelDocExtension
                  Dim swCustomPropMgr as sldworks.custompropertymanager
                  dim strValOut as String
                  dim strResolvedValOut as String
                  swModelDoc = swDraw
                  swCustomPropMgr = swModelDocExt.CustomPropertyManager("")
                  'this line gets the value of the custom property
                  swCustomPropMgr.get4("Dwg No", False, strValOut, StrResolvedValOut)
                  'strValOut or strResolvedValOut will be the value you need.
                  Greg
                    Keith Hooks
                    Are you trying to access a property of a model contained within the drawing?  In that case, I believe you'll need to get a pointer to the ModelDoc2 for the part/assembly contained in the drawing.  I've done it like this:
                                swDraw as DrawingDoc
                                swPart as ModelDoc2
                                swView as View
                                set swDraw = swModel
                                swView = swDraw.GetFirstView()    //return the sheet
                                swView = swView.GetNextView()   //returns the first view
                                Debug.Print("Selecting a component from a drawing view: " + swView.GetName2());
                                swPart = swView.ReferencedDocument;
                    From there, get the properties directly from the part/assembly model.
                        Keith Hooks
                        Remember that $PRPSHEET refers to the property of a model in a view on the drawing.  I don't believe you can access it directly - you need to first navigate there via my comments above.  Get the sheet, then get the view, then get the model referenced in the view.  Then access that model's properties via ModelDoc2.Extension.
                            Jason Wilger
                            Keith,
                            Thanks for the information. I tried adding your code to my macro, but I get Invalid Syntax errors when I try to run. Maybe this is a C# to VBA transfer problem. If you have any suggestions, that would be great.
                                Greg Johnson
                                Can you post your code as it is written now?
                                  Keith Hooks
                                  I apologize for the poor VBA syntax.  I program in C# primarily, but I took a stab at the VB syntax.  My hope was that you could use it as a template to see what objects are being manipulated.  Good luck.
                                      Greg Johnson
                                      Jason,
                                      Put a single quote ' in front of the // in Keith's code. That should comment the unneeded information from those lines. Keith, correct me if I'm wrong but the // is the comment syntax in C#. The line should be...
                                      set swView = swDraw.GetFirstView() '//return the sheet
                                      set swView = swView.GetNextView() '//returns the first view
                                      set swPart = swView.ReferencedDocument
                                      I'm unsure if you will need the set statement. Some versions of VB require it some don't.
                                      Greg Johnson
                                          Jason Wilger
                                          Greg,
                                          Back at work today. I tried the suggestions you made, but still get errors. I have pasted the code below. There is some of Keith's code and some of your code. I am getting obect required and type mismatch errors now. Thanks for all of your help.
                                          Dim bRet As Boolean
                                          Dim i As Long
                                          Dim swModelDoc As SldWorks.ModelDoc2 'new
                                          Dim swModelDocExt As SldWorks.ModelDocExtension 'new
                                          Dim swCustomPropMgr As SldWorks.CustomPropertyManager 'new
                                          Dim strValOut As String 'new
                                          Dim strResolvedValOut As String 'new
                                          Dim dwgno As String 'new
                                          Dim dwgno1 As String 'new
                                          file = Dir(f)
                                              Do While file <> ""
                                              filen = f + file
                                              Debug.Print file
                                                          Set swDraw = DrawingDoc 'new
                                                          Set swPart = ModelDoc2 'new
                                                          Set swView = View 'new
                                                          Set ModelDoc = swPart 'new
                                                          Set swView = swDraw.GetFirstView() 'new
                                                          Set swView = swView.GetNextView() 'new
                                                          Debug.Print ("Selecting a component" + swView.GetName2()) 'new
                                                          Set swPart = swView.ReferencedDocument 'new
                                                          Set swModelDoc = swDraw 'new
                                                          Set swModelDocExt = swModelDoc.Extension 'new
                                                          Set swCustomPropMgr = swModelDocExt.CustomPropertyManager("") 'new
                                                          dwgno = swCustomPropMgr.Get4("Dwg No", False, strValOut, strResolvedValOut) 'new
                                                          dwgno1 = strValOut 'new
                                                          Set Part = Nothing
                                                  Else
                                              file = Dir()
                                          Loop
                                          Jason
                                              Keith Hooks
                                              It looks like you're going through all of the drawing files in a folder and saving them out as TIF files.  Just so I'm clear - you want to name the TIF file the same as the Referenced Model's "Dwg No" field.  Is that right?  You're not trying to use the drawing's custom properties as the filename.
                                                Keith Hooks
                                                I dug into this a little bit more.  I commented out some lines that I felt weren't neccessary and it 'seems' to execute without errors.  Your drawing is the file you're actually saving, so you can still use the swModelDoc that represents the drawing throughout the execution.  I also don't think there's any reason you need to get a handle to the activesheet once you've activated it since the properties you want are in the referenced model.
                                                I also recommend using the Path class to get your file extensions or otherwise manipulate a file Path.  It will save you a ton of headaches.  There are also simpler ways to iterate over files in a directory (especially in .NET 4.0) but I didn't change that here for now.
                                                I did comment out the line that sets the swTiffPrintToScale option because it gave me an inexplicable compile error.  Hopefully it works for you.
                                                Public swApp As SldWorks
                                                    Public Sub main()
                                                        'Dim Feature As Object
                                                        Dim swSheet As Sheet
                                                        Dim swDraw As DrawingDoc
                                                        Dim swPart As PartDoc
                                                        Dim bRet As Boolean
                                                        Dim f As String
                                                        'Dim i As Long
                                                        Dim file As String
                                                        Dim filen As String
                                                        'Dim filetype As String
                                                        Dim filename1 As String
                                                        Dim lcasefiletype As String
                                                        'Dim namelength As Integer
                                                        'Dim namelength1 As Integer
                                                        Dim vSheetProps As Object
                                                        Dim swModelDoc As ModelDoc2 'new
                                                        Dim swView As View
                                                        Dim swModelDocExt As ModelDocExtension 'new
                                                        Dim swCustomPropMgr As CustomPropertyManager 'new
                                                        'Dim dwgno1 As String 'new
                                                        'Const swTiffPrintScaleToFit As Long = 28
                                                        'swModel = swApp.ActiveDoc
                                                        'Debug.Print("PrintScaleToFit        = " + Str(swApp.SetUserPreferenceToggle(swUserPreferenceToggle_e.swTiffPrintScaleToFit, True)))
                                                        Debug.Print("ScreenOrPrintCapture   = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffScreenOrPrintCapture, 1)))
                                                        'Debug.Print("allorcurrentsheet      = " + Str(swApp.SetUserPreferenceIntegerValue(swallorcurrentsheet, 1)))
                                                        Debug.Print("ImageType              = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffImageType, 0)))
                                                        Debug.Print("CompressionScheme      = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffCompressionScheme, 2)))
                                                        Debug.Print("PrintDPI               = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffPrintDPI, 200)))
                                                        Debug.Print("PrintPaperSize         = " + Str(swApp.GetUserPreferenceIntegerValue(swTiffPrintPaperSize)))
                                                        file = Dir(f)
                                                        Do While file <> ""
                                                            filen = f + file
                                                            'namelength = Len(filen)
                                                            'filetype = Mid(filen, (namelength - 5), 7)
                                                            'namelength1 = Len(file)
                                                            'filename1 = Mid(file, 1, (namelength1 - 7))
                                                            Debug.Print(file)
                                                            Debug.Print(filename1)
                                                            'lcasefiletype = LCase(filetype)
                                                            lcasefiletype = Path.GetExtension(filen)
        'Part = swApp.OpenDoc6(filen, 3, 0, "", longstatus, longwarnings)
        swModelDoc = swApp.OpenDoc6(filen, 3, 0, "", longstatus, longwarnings)
        'swModelDoc = swApp.ActiveDoc
        swDraw = swModelDoc
        'swSheet = swDraw.GetCurrentSheet
        'vSheetProps = swSheet.GetProperties
        Debug.Print("Selecting a component" + swView.GetName2()) 'new
        swModelDocExt = swPart.Extension 'new
        'dwgno1 = strValOut 'new
        Debug.Print("  TemplateName              = " & swSheet.GetTemplateName)
        Debug.Print("  PaperSize                 = " & vSheetProps(0))
        Debug.Print("PrintPaperSize         = " + Str(swApp.SetUserPreferenceIntegerValue(swTiffPrintPaperSize, vSheetProps(0))))
        swModelDoc.SaveAs2(f + filename1 & ".TIF", 0, True, False)
        'swPart = Nothing
        swApp.CloseDoc(filen)
                                                            Else
                                                        Loop
                                  Jason Wilger
                                  With some help from Keith, Greg, and some other threads, I got the macro to work. Here is the final product:
                                  Dim swView As SldWorks.View
                                  Dim bRet As Boolean
                                  Dim f As String
                                  Dim file As String
                                  Dim filen As String
                                  Dim strModstring As String
                                  Dim strfilename As String
                                  Dim strresfilename As String
                                  Dim sname As String
                                  Dim sValue As String
                                  file = Dir(f)
                                      Do While file <> ""
                                      filen = f + file
                                      Debug.Print file
                                                  Set swModelDoc = swApp.OpenDoc6(filen, 3, 0, "", longstatus, longwarnings)
                                                          strfilename = swView.ReferencedDocument.GetPathName
                                                          strresfilename = Left(strfilename, Len(strfilename) - 7)
                                                          strModstring = Right(strresfilename, intcount)
                                                  sname = "Dwg No"
                                                  sValue = swView.ReferencedDocument.CustomInfo2("", sname)
                                                          swModelDoc.SaveAs2 f + sValue & ".TIF", 0, True, False
                                                  Set Part = Nothing
                                          Else
                                      file = Dir()
                                  Loop
                                  I did a test run with 50 drawings and it worked seamlessly. I think a lot of the problem is with the VB version. I am currently running 2012, and this may be the issue.
