2 Replies Latest reply on Jul 22, 2013 10:37 AM by Mark Sloans
    Invalid Procedure or argument error.
    Mark Sloans
           Im fairly new to the solidworks api so please bare with me. I have managed to write quite a bit of code for a project im working on but Im having a little trouble understanding why i keep recieving this argument error on a certain line of code. I have tried declaring it differently but it did not seem to fix the issue so ill ask the pros. It could be something really simple that i keep overlooking. Any thoughts are appreciated. These are only sections of the code(too long to list all of it) if i have missed any important info let me know.
      *** = Line of code that is causing the error
      Dim myDimension6 As Object
      Dim myDimension7 As Object
      Dim myDimension8 As Object
      Dim myDimension9 As Object
      Dim Trim As String
      Dim Trim1 As String
      Dim PanL As String
      Dim IPS As String
      Dim DPS As String
      Dim count As String
      Dim count1 As Double
      'Retrieves the Infeed Sprocket Pitch
      Set myDimension6 = Part.Parameter("SprocketPitch@Sketch1@" & Prefix & " INFEED PAN.Part")
      Isprkt = myDimension6.SystemValue * Conv
      If Isprkt = 0 Then
      MsgBox ("Infeed Sprocket Pitch Error")
      'Retrieves the Discharge Sprocket Pitch
      Set myDimension7 = Part.Parameter("SprocketPitch@Sketch1@" & Prefix & " DISCHARGE PAN.Part")
      Dsprkt = myDimension7.SystemValue * Conv
      If Dsprkt = 0 Then
      'Retrieves the Infeed Intralox A Dimension
      Set myDimension8 = Part.Parameter("IntraloxAMin@Sketch1@" & Prefix & " INFEED PAN.Part")
      InA = myDimension8.SystemValue * Conv
      If InA = 0 Then
      MsgBox ("Infeed Intralox A Value Error")
      'Retrieves the Discharge Intralox A Dimension
      Set myDimension9 = Part.Parameter("IntraloxAMin@Sketch1@" & Prefix & " DISCHARGE PAN.Part")
      DisA = myDimension9.SystemValue * Conv
      If DisA = 0 Then
      MsgBox ("Discharge Intralox A Value Error")
      ***IPS = (0.3125) + (0.5 * Isprkt) + Sqr((0.5 * Isprkt) ^ 2 - (InA - 1.25) ^ 2) + 2
      DPS = (0.3125) + (0.5 * Dsprkt) + Sqr((0.5 * Dsprkt) ^ 2 - (DisA - 1.25) ^ 2) + 2
      PanL = Length - IPS - DPS - 108
      count = (PanL / 108)
      count1 = Int(count)
