Strange results...
Question asked by Justin Broughton on Jul 18, 2013
Latest reply on Jul 18, 2013 by Jared Conway
Here's a picture of what I have been doing. The wire frame on top is actually transparent steel. When I ran the thermal simulation for the first time, there was none of the copper towards the top. The very first time I ran it, the maximum temperature was 150 degrees celsius, way higher than the point of failure for the IC units. The second time, I added some small details like a few copper rods going through the IC units and distributing the heat throughout the copper layers of the board itself. The second simulation was better than the first and the maximum temperature was 130 degrees. Still too high, but a definite improvement. So I added a copper heat spreader that is attached to the IC units with the highest power outputs. The intention was to distribute some of the heat to the copper and to the stainless steel cover. However...the maximum temperature was higher than the second simulation.  It might have been lower than 150 degrees but I cut off the simulation when it hit 135 degrees celsius. What's the reason behind this? I'm almost positive it's something I done incorrectly but I don't know which inputs were different.  Solutions? Ideas?
