Hi
I'm trying to make a motion analysis of a car with SW2013 sp2. I upload the assembly. Please check the mates. If you run the motion study 1, it will works fine, but when you unsupress the suppressed parts it won't work and I get error messages.
Thanks.
which assembly? i took a look at the one that is called foossXXX.sldasm
2013 SP3.0
i can play your simulation
when i try to calculate your simulation there is a long rebuild time but it does calculate. there are some issues like the contact not working great but that can probalby be fixed with a higher FPS.
when i unsupress everything at the bottom of your feature tree, i don't get a chance to try the motion. there are many part and mate errors. those will need to be fixed first.
then what i would highly recommend doing is putting things into sub assemblies and minimizing the number of mates at the top level. there are a bunch of articles/videos in the solidworks world proceedings that i'd recommend taking a look at.
i'm also not sure what your end goal is, but i'd also be looking at simplifying the assembly as much as possible.
