I am trying to render an assembly while in a seciton view but somehow I am losing the surface color I applied.
has anyone run into this problem and found a solution?
I have searched and searched the blogs but haven't come to find much.
SW2013
You'll have to push your assembly cut to the part level (there is a check box for that in the property manager). Then in the part you'll need to apply an apperance to the part and to the face where the section cut is.
