i have an asm file consist of a top cover, pcb asm and a lower cover.
i did an interference check. select covers and pcb asm.
i expect the result to be pcb asm (as 1 entity) against top cover, lower cover. each e-component againts each other no need to show.
i dont want the result of intereference among the e-components.
it only show which area of covers interfere with pcb asm.
is that possible ?, how to set ?
jack.
Hi Jack,
While in the Interference Detection tool, there is a pane on the left side called Options (it might be rolled up). You'll find a check box for "Treat subassemblies as components" that will control this behaviour.
Cheers,
Jim.
