DWDavid Watkins16/07/2013
I am trying to write a macro that will test if the open file is read only and if so it will do something but I can't get it to work. As I step thru the code I get to "ReadWariteState = swModel.IsOpenedReadOnly()" and that is working (if the file is read only it is true, if not it is false) but when I try to test if that is true It skipped to the else when it should have done the then. What am I doing wrong?
David
Dim ReadWariteState As Boolean
    'connect to SolidWorks and the active document
    Set swModel = swApp.ActiveDoc
    If ReadWariteState = True Then
        MsgBox "test"
    Else
         Exit Sub
