Hi all,
Just trying to get this call working in an example before implementing in a larger program and I am up against a wall! I am getting an error ("for each control variable must be a variant or object") with the blue line below highlighted when i try to run this which is odd to me becase brokenRef is set as an object in this code.
It is worth metioning that this was the example for VB.NET and I have done my best to tweak it for VB6
Also:
-yes i have my license key
-yes I have registered all dll's and added ref's to project etc...
-yes i have read the api help exhaustively concerning this.
Any thoughts?
Const sLicenseKey As String = "your_license_code" 'Specify your license key
Const sDocFileName As String = "drawing_document_with_external_references"
Dim swClassFact As SwDMClassFactory
Dim swDocMgr As SwDMApplication3
Dim swDoc As SwDMDocument16
Dim swSearchOpt As SwDMSearchOption
Dim nDocType As Long
Dim nRetVal As Long
Dim vDependArr As Object
Dim vDepend As Object
Dim vBrokenRefs As Object
Dim vIsVirtuals As Object
Dim vTimeStamps As Object
' Determine if document is a drawing
If InStr(LCase(sDocFileName), "slddrw") > 0 Then
nDocType = SwDmDocumentType.swDmDocumentDrawing
Else
' Not a drawings file,
nDocType = SwDmDocumentType.swDmDocumentUnknown
' so do not open
Exit Sub
Set swClassFact = CreateObject("SwDocumentMgr.SwDMClassFactory")
Set swDocMgr = swClassFact.GetApplication(sLicenseKey)
Set swSearchOpt = swDocMgr.GetSearchOptionObject
Set swDoc = swDocMgr.GetDocument(sDocFileName, nDocType, False, nRetVal)
Debug.Assert (SwDmDocumentOpenError.swDmDocumentOpenErrorNone = nRetVal)
Debug.Print ("File = " & swDoc.FullName)
Set vBrokenRefs = Nothing
Dim brokenRef As SwDmReferenceStatus
Set vIsVirtuals = Nothing
Dim isVirtual As Boolean
vTimeStamps = Nothing
Dim timeStamp As Double
vDependArr = swDoc.GetAllExternalReferences4(swSearchOpt, vBrokenRefs, vIsVirtuals, vTimeStamps)
If vDependArr Is Nothing Then
Exit Sub
Else
Debug.Print ("External references")
For Each vDepend In vDependArr
Debug.Print (" " & vDepend)
Next vDepend
Debug.Print ("Reference statuses as defined in swDmReferenceStatus")
For Each brokenRef In vBrokenRefs
Debug.Print (" " & brokenRef)
Next brokenRef
Debug.Print ("Virtual component?")
For Each isVirtual In vIsVirtuals
Debug.Print (" " & isVirtual)
Next isVirtual
Debug.Print ("Timestamps")
For Each timeStamp In vTimeStamps
Debug.Print (" " & timeStamp)
Next timeStamp
