In a single transition, is it possible to increment the revision and then create a PDF of the drawing displaying the new revision? I have a workflow that increments the revision, and I added a task to create the PDF, but the resulting document showed the old version of the PDF. Did I do something wrong?
Of a SolidWorks file?
Are you updating the data card?
Is the data card linked to the document?
If you open the document after the pdf is created, do you see the new revision value?
